C6501 - 2.5mm image shift every 2nd sheet
  • resolute
    • 28
    [Misc] C6501 - 2.5mm image shift every 2nd sheet
    I Have a very strange problem. Printing 13 x 19 Sheet - 10PT Carolina C2S Stock Coated GO 210-256gsm - every 2nd sheet the back to back registration is off by approx. 2.5mm. For example if I send down 10 sheets - autoduplex - Sheet 1 is good, sheet 2 is off, sheet 3 is good, sheet 4 is off -- and so on - It just affects every 2nd sheet. The strange part is that it is off by the exact same amount. Any suggestions?
  • sbillis
    • Nov 2008
    • 95
    Restart Timing, Centering, FD, CD adjustments are made?
    auto centering sensor enabled or disabled?
    • resolute
      • 28
      I have done the adjustments - even went through the entire tray alignment procedure.
      How do I check regarding the Auto Centering Sensor?
      • sbillis
        • Nov 2008
        • 95
        dipsw
        26-4=0 for on =1 for off ADU
        26-5=0 for on =1 for off LU,PF
        maybe reverse for adu-pf
        • sbillis
          • Nov 2008
          • 95
          do you have any news on this issue?
          • HORSE
            • Mar 2008
            • 185
            I find that the Auto Centering tends to jump by 5mm.
            Also it would be unusual to alternate good/bad/good/bad every 2nd sheet, I find that Auto centering tends to jump after maybe 30 or so sheets and then jump back after 20 or so sheets.
            Laughing......
            • Stirton.M
              All things Konica Minolta
              • Oct 2009
              • 1804
              I agree with Horse, turning off Auto center fixes the problem. After this, its a matter of adjusting the registration manually for all the trays. Can be a bit of a bear in the doing, but reliable. Use of image shift in the driver or CWS can tweak the minor deviancies.
              This problem only shows itself on glossy stock, at least this is what I had noted. Bond or uncoated paper, the sensors work without fault.
              Of course, the sensors can also be replaced.
              The TSB information
              Solution ID
              TAUS0701183EN* Solution Usage 17
              Description
              Intermittent half-inch image shift on second side in the main scan direction.
              Solution
              PROBABLE CAUSES:
              1. Failed Image Processing Board (IPB).
              Verify failed Image Processing Board by swapping it with another board if possible. Replace the IPB as necessary (p/n A03U H020 28 for bizhub PRO
              C6500/C5500 and p/n A0U0 H020 02 for bizhub PRO C6501/C5501 ).
              2. Failed ADU centering sensor (PS65).
              Replace the ADU centering sensor (p/n 56UA 8551 0E for bizhub PRO C6500/C5500 and p/n 56UA 8551 0E for bizhub PRO C6501/C5501 ).
              "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
              ---Groucho Marx
              Please do not PM me for questions related to Konica Minolta hardware.
              I will not answer requests or questions there.
              Please ask in the KM forum for the benefit of others to see the question and give their input.
              • HORSE
                • Mar 2008
                • 185
                I would say that the problem is caused by the Black guide plates wearing 'Silver'
                I have opened up both the PF & ADU units as of late for a physical observation and have noticed that beneath the area that the long centering sensor is located the black paint has worn away to reveal the silver of the metal showing through. Also as for the PF paper dust is another issue.
                Laughing......
                • sbillis
                  • Nov 2008
                  • 95
                  The TSB information
                  How can find out what is TSB information? Is something like AAS?
                  please send me a pm if you like about TSB.
                  • HORSE
                    • Mar 2008
                    • 185
                    TSB... Technical Service Bulletin
                    Laughing......
