error code C-5002 on bizhub pro 6500
  • printsibiu
    • Jun 2025
    HI my 6500 give an error C-5002 when i start it up.Can you give any solution?
  • ESA
    I haven't dealt with this code to-date but the following is list from the service manual. What was happening before code. Did you attach any new finisher of accessories?
    Main body
    Communication
    abnormality
    C-5002 24VDC abnormality.
    Abnormality signal was continuously
    detected for the specified
    time after the specified time from
    REN/2 ON.
    Main body
    stops immediately
    and main
    relay (RY1) is
    turned OFF.
    DC power unit/2 (DCPS/2)
    • printsibiu
      I discovered the problem NF60 is blown out near ICP 31. can i change it or be changed all board PRCB?
      • sbillis
        • Nov 2008
        • 95
        how do you discovered NF60 is blow? please explain.
        check ICP32.
        if anything fails on PRCB I think must be replaced all the board... and is very expensive!
        • ESA
          It's tricky to replace board parts as you must source compatible parts. If you have nothing to lose try, but KM protocol seems to be board replacement.
          • Herrmann
            • Jan 2006
            • 792
            if you are experienced in soldering printed circuit bords, it is no problem to change a soldered fuse; done that several times by myself with success
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • printsibiu
              C-5002
              It was easy to see that NF60 was burned, was black around him.I checked all ICP and all were good,one is less,it is near NF60.So finally what is NF on PRCB it is noise filter or an capacitor?
              • sbillis
                • Nov 2008
                • 95
                oh yes, you can visually check also a board...
                a capacitor can work as noise filter
                • keraton
                  Keraton
                  • Aug 2023
                  • 1
                  Hello, Was there any body which faced error code C-5002 ? what was the finding, potential cause and the effective corrective action taken?
                  • prakashshetty
                    • Aug 2024
                    • 2
                    Hi, Another probable cause can be the ADU harness cable connecting the Duplex and Chassis been peeled off and getting grounded/shorted. Check for wire coating peel off or pinched. Thanks.
