BIZHUB C220
  • thuo
    • 155
    BIZHUB C220
    Blurred images when copying after replacing scanner unit in bizhub c220.
    please assist
  • BIG PAPA
    Da Boss
    • 234
    What exactly did you replace? The CCD, Mirrors, Glass, or the whole thing? Hate to point out the obviuos, but it is probably something you did.
    sigpic
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      I agree with Big Pappa.
      Follow the service manual regarding the replacement of this. You likely overlooked a very important step.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • thuo
        • 155
        I changed the lamp and the ccd. followed the manual to the letter but the copies are still blurred.
        • Stirton.M
          • Oct 2009
          • 1804
          Might seem like a dumb answer, but clean the lens???
          Any other adjustment is not recommended, but you may have to adjust the focal length of where the CCD sits. I would defer to tech support with KM on this matter.
          ---Groucho Marx
          • Gerg?
            • Jul 2008
            • 67
            Hello
            Can I ask, why did you change the CCD?
            I have problem, with the colors. Printed pictures are fine, but in copy function the eveything is more green than it should be.
            • SmellsHot
              Head Tech
              • 512
              Make sure the CCD is seated properly, all screws are tigthened and it's aligned correctly
              Everyone has the right to be stupid. Some people just abuse this privelage more than others
              • Chip Resets SA
                • Sep 2010
                • 46
                Did you put all the screws you took out back in the same order? I've had it where one screw was too long and just that mm or two blurred the whole image! Don't know if it's that same on the C220 but worth a try!
                • emujo
                  • Jun 2009
                  • 3009
                  Had one of the black plastic sliders the lamp assy moves on pop out, caused the x lamp/1st mirror assy to be slightly skewed, wasn't through ADF, but scans from platen were way out of whack. Emujo
                  • eg101
                    • Jan 2005
                    • 131
                    Is everything you run blurred or just copies from the glass?
