Konica bizhub 420
  • Mwema
    [Error Code] Konica bizhub 420
    I have this machine which is giving me error code c-6701 at startup what is the cause and solution?
    can somebody help?
    thanks.
  • albasoul06
    Image processing abnormality
    1 - CCD board (CCDB)
    2 - Exposure lamp (L1)
    3 - L1 inverter (L1 INVVB)
    4 - Scanner motor (M2)
    5 - Overall control board (OACB)
    • Kmdurrin
      Copy/Print/Network Tech
      • Dec 2008
      • 132
      Description
      C-6701 (C6701) at power up.
      Solution
      PROBABLE CAUSES:
      1.Failed Overall Control Board (OACB). Check ICP3 on the OACB. If it is OPEN, check for shorts and replace the Overall CB (p/n 50GA -930 3K for bizhub 360 and p/n 50GA-930 1H for bizhub 420/500).
      2.A communication issue between the CCD and OACB. This issue usually appears shortly after replacing or removing the OACB (Overall Control Board). Please check the flat cable between the CCD and OACB. Make sure it is undamaged and connected properly. Replace the CCD cable (p/n 50GA 9050 0) if re-seating it has no effect on the service code.
      Parts: Its what your copier craves!
      • remati
        • 149
        yes ....is relacted of the scanner as people said...
