C203 Intermittent lock-ups
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Try this: First disable sleep mode, disable Direct SMB Hosting, set the copier network card to 100M speed, and if you have a 1 Gig programmable switch set the port that the copier is connected to to 100M, if you have a 1 Gig switch that is not programmable put a cheap mini switch between the copier and the network jack. Let me know if you have any more lockups?
    Now into Ip TV KODI Boxes
    • Talligen
      Bad RAM! That's what was causing the lockups. It's been a couple of weeks now and since replacing the ram (not the NVRAM) the copier hasn't locked up once.
      Thank you all for your help. I hope this thread might help you in the future when faced with an intermittant locking-up copier.
