Removed sd-503 finisher machine says its still there (c252)
  • dinkyoaf
    • Sep 2010
    • 63
    Technician removed the SD-503 finisher off of a BizHub c252 but the machine still thinks it's there. Did he miss a jumper or some other important step?
  • Choclit007
    • Oct 2010
    • 58
    SD-503 option to FS-514... Need more details...
    So was the SD-503 Saddle Stitcher removed from the FS-514 only or was the FS-514 finisher removed/unplugged from the copier...?
    If only the SD-503 was removed was the adjuster plate screw loosened and moved back towards the copier? Were the upper tray guides moved back up one level?
    • jma676
      Expert Tech
      • Mar 2009
      • 323
      Ok, you need remove "Short Connector" in the FS-514, check installation manual.
      • dinkyoaf
        • Sep 2010
        • 63
        Anyone have a PDF version of the manual I could have by chance?
        • B0265
          • Jan 2007
          • 718
          This might be a dumb question, but did he remember to remove the creasing unit?
