Bizhub C253
  • Ngwanomontle
    • Jul 2025
    [CQ] Bizhub C253
    Hi all please assist i have a bizhub C253 that is displaying a time ahead on scan to email i went to date and time settings and the time is correct but when i scan something it displays a 2 hours later time instead i hope i make sense how can i resolve this matter thanks.
    question 2: how do i set the control pannel to display user names automatically when they select scan/fax button instead of them selecting the address book button.
    thanks again
  • kingarthur
    • 1356
    to correct the scan time... go to admin mode, then in the time ,date setting part, change the "time zone"
    when programming the user names, select "main" instead of the "ABC" etc
    • Ngwanomontle
      thank you for the reply ok i have changed the timezone it was GMT 0:00 i changed it to +2:00 and all is good now, but the scan/fax on the control pannel is still th same when i press fax/scan button it defaults to "direct input" and i want it to default to Addressbook how do i change that?
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        It is under the utility key, user settings, display settings. Should be pretty obvious when you look there...
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • Ngwanomontle
          wow we learn something knew everyday hey thanks a lot guys Kingarthur thank you and @Stirton.M thanks i have just set address book as a default and by the way i like your profile picture/avatar im very fond of cats i think it's really cute it made me laugh :-)
          • Stirton.M
            • Oct 2009
            • 1804
            I like it too....spunky little guy isn't he?
            ---Groucho Marx
