bizhubpro c6501
  • thuo
    • 156
    bizhubpro c6501
    hi
    have bizhub c6501 whose printout have banding checked drum units & Dev units all o.k.
    advise on any settingsUntitled-4.jpgUntitled-2.jpg required. this happens on solid printouts.
  • ineo+6501
    • Mar 2010
    • 262
    The handwritten comments on the pages suggests you have just serviced the machine, is this correct?
    • thuo
      • 156
      Thats true. i have two c6501 which hardly last more than 2 weeks .before they start misbehaving .i normally replace the consumables following the instructions to the letter. initial printouts are are perfect.
      anything i am missing
      assist
      thanks
      • ineo+6501
        • Mar 2010
        • 262
        It is a must that you clean the dust proof glass for each laser. Also, the 200k service replacement list does not suggest you fit new charge assemblies.
        We change the charge assemblies on each service as the charge grids do not seem to be as good as they should be. And the charge assemblies are pretty cheap.
        We always make sure that we take out and thoroughly clean the colour registration assembly, and vac out all of the ducts etc as best we can to try and keep the workings as dust free as possible.
        • HORSE
          • Mar 2008
          • 186
          What direction are those samples coming out of the machine?
          At a guess I reckon that its the grids, I NEVER clean the grids because you will end up with prints like above. I wouldn't even touch the grids or change them.
          I just replace the whole charge units not worth the hassle.
          No thats because for a C6501 they are replaced at 100K
          Parts.pdf
          Laughing......
          • ineo+6501
            • Mar 2010
            • 262
            Your absolutley right HORSE, the charge coronas are mentioned for replacement at 100K in the theory of operation manual.
            But oddly there is no mention of them in the maintenance section of the field service manual.
            200kservice.pdf
            • jma676
              Expert Tech
              • Mar 2009
              • 324
              Konica Minolta Bizhub Pro C5500/C6500/C5501/C6501/
              Charging Coronas
              Unit Replacement Period
              More precisely, the duration of Charging Coronas, is determined by the time of use,
              Ex : / 70 Hours />
              (Time estimated by KM).
              Charging Coronas /PM 100K/ both the Bizhub Pro C6500/C6501, the Bizhub Pro C5500/C5501 this period is lower / 75K/.
              Is a period estimated relative to a Monthly Prints Volume.
              The right thing, would be for you to control the Percentage being of Use when you get to /100%/, Units must be Replace.
