Di450 - black display, no fans etc
  • Darren King
    replied
    I would check for a pinched wire somewhere around the fuser drive assembly
    Hope this helps
    Darren
  • Downunder
    replied
    it could be the main board or if my memory is right there is a small board in close proximity to the power plug on the side of the machine(exit end) could be that.
  • Toner Boy
    replied
    thanks, we'll try and hunt down a switch for it, maybe off a EP1083 - think its the same as the analogs.
  • fixthecopier
    replied
    Go back to that switch, it could be bad. I have had to change them.
  • Toner Boy
    started a topic Di450 - black display, no fans etc
    We had recently replaced the fuser drive clutch (back panel). One week later the machine won't power up. Power switch won't flip all the way on, power activity lights are active on the main pwb and scanner control?, no fans, no engine cycling, nothing. Any ideas? Voltage at AC outlet is 117V. We also pulled the fuser out and tried it, no luck.
