What in H*ll is this. KM C203
  • leo
    • Jun 2008
    • 64
    prints Pink overall, also in framingarea, but only in colormode.
    B/W copies/prints are OK.
    IU IS renewed.
    LEO
  • CKiiza
    • Feb 2010
    • 77
    It's probably the magenta print head that's having a problem.
    Switch it with cyan unit. if the background is cyan then you will have to change the print head
    • mrwho
      Major Asshole!
      • 4299
      Either that or an HV contact is bent or broken.
      I've also had problems on a C250 with a bad flat cable at the back of the machine, although I don't know the equivalent of that problem on the C203.
      When you say IU is renewed you mean it is new and not chipped or rebuilt.
      Mascan42
      Ibid
      • leo
        • Jun 2008
        • 64
        thats correct, changed with a new KM IU,
        • SmellsHot
          Head Tech
          • 512
          yes definetely a print head issue! They had a bulletin out where they were replacing all PH units FOC...they were having a very high failure rate....
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • leo
            • Jun 2008
            • 64
            bulletin, yes i knew this but all prinhead had been replaced before, ca 2 monhts ago, so i thought....
            if u send in the prinhead to claim warranty the printhead will (probably) be fixed at the factory or somwhere and sent out in the field again.
            the PHD assy that I putted in the first time had been in for factoryfix.
            Yes it was the printhead.
