Hi All
I Recently Replaced A Toner Supply Unit On A B500 , Right After That I Got A Code 6702 I Stripped Everything Down Again To Check For Unplugged Connectors Or Maybe To See If I Pinched A Wire And Everything Seemed Fine , I Dont Know If This Code Was Put There By Mistake Or Just As A Coincidence The Manual Says Agc Abnormality And Agc Counter Overflow, Check Ccd Board, L1 Exposure Lamp ,l1 Inverter ,scanner Motor M2 Or Overall Control Board. When I Reset The Machine Everything Works Fine Accept For The Code That Appears Immediatly I Can Even Do The Non Image Erase Adjustment And Access Various Other Adjustments , But Cannot Get Rid Of This Code.
Any Suggestions Welcome ,please
