Konica Minolta Bizhub C250p error code c2552 and than P6-P21
  • copyalbania
    • Aug 2009
    • 165
    Hello Friends,
    I am servicing a bizhub c250 printer version and it makes exactly 9 copies and go into code c2552 and after one day in maximum show error code p6 and p21 and now cyan color is showed.
    I have check the TCR cleaned but the same thing also i have put a new cyan toner cartridge.
    Anyone to help in this issue?
  • D Colour
    • Oct 2008
    • 213
    Re: Konica Minolta Bizhub C250p error code c2552 and than P6-P21
    Have a look at this. Especially the part on t/c ratio. This is on the C250 copier, not sure how similar the printer is!
    http://www.copytechnet.com/forums/ko...tml#post238770
    Everything that has a beginning, has an end.....
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Darren King
        copiertech
        • 652
        Definitely related to the cyan IU. Likely has failed. Replace cyan IU.
        Hope this helps
        Darren
        • nightshade
          Chromographic Supremesist
          • 158
          You could have a failure in the print head(lsu). If in a humid environment fogged mirrors in the lsu can and will cause this. Also a bad motor for changing the angle of the mirror in the lsu.
          Replace the cyan iu but if the problem comes back, replace the print head.
