bizhub 600
  • NEOTECH
    • Dec 2010
    • 69
    [Misc] bizhub 600
    i have a problem in fuser lamp not trun on and not showing any error code i cheack fuser unit other copier machine is working properly.
    if someone face like problem plz help me.
    thank's
  • Rajeevk
    Re: bizhub 600
    Do you replaced the fusing or tried to rest any error code?
    thank's
    • toner head
      • Sep 2010
      • 10
      Re: bizhub 600
      If you suspect fuser because machine is saying "warming up" you are barking up wrong tree.That can be because the handle is not in the vertical position or you are having a toner issue in developer. You can run process control and see if any errors occur. Clean process unit sensors if an error occurs.
