Bizhub 43
  • thuo
    • 155
    Bizhub 43
    Hi all
    have 2 bizhub 43 which were working quite well til recently . you power it on then shows please wait on the display for a short time then resets and goes to please wait again. both machines developed same problem in a span of one week. how can i go about the problem is it a common one with this machine
  • tommytran54
    Re: Bizhub 43
    it has to do with the fusing unit. maybe the thermal sensor is dirty or about to get bad. the best solution is replace the fusing unit
    • thuo
      • 155
      Re: Bizhub 43
      I have replaced fuser unit with a new one but machine behaving the same
      • mitchl
        • Apr 2007
        • 501
        Re: Bizhub 43
        What the hell is a BH 43 must be a Bongo Bongo land model................... If it keeps resetting like you say it sounds like it has an abort code, if it was a fuser problem it should display a code that wont reset by turning it off and on. We dont have that model in the states so I have zero info, sorry!
        • SmellsHot
          Head Tech
          • 512
          Re: Bizhub 43
          It's a brand spankin new machine. The scanner of a C35 and the body of a 423....at least thats the rumor...have yet to see one either.
          Sorry I cant help you. Prolly a firmware issue, would be my guess....see if you can reload.
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • mitchl
            • Apr 2007
            • 501
            Re: Bizhub 43
            Geez KM would never send a new model out half baked!
