error code for c 5370 0nc450 machine
  • bkamoga
    • Oct 2011
    • 31
    [Error Code] error code for c 5370 0nc450 machine
    Hi to all guys overthere i have astrange error code for on a c450 it is not inthe service mode the error is c 5370 i have tried to trouble resset but nothing and i dont know what is the problem somehelponwhat the problem is waiting 4 the reply
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: error code for c 5370 0nc450 machine
    • bizhub C351/C450
      CAUSE: A loose connection between M27 and PWB-SIF PJ8.
      SOLUTION: Follow the wiring from M27 (PWB-MFP cooling fan) to PJ8 of the PWB-SIF. There is an intermediate connector on the harness that can easily become dislodged when the cage containing the circuit boards is removed. Reseat the connector to M27 at the motor.
    • bkamoga
      • Oct 2011
      • 31
      thanks alot the problem was solved
      come again next time
