Part Number 9J07 R707 00, It is the gear assy and motor in the ADF that raises the paper. Need to find supplier for Konica Bizhub C253 parts. Used or new doesn't matter. Thanks so much
Need part for a Konica/Minolta DF-611 ADF (on C253 K/M), Any Ideas
Re: Need part for a Konica/Minolta DF-611 ADF (on C253 K/M), Any Ideas
Would You like to explain us what is the matter? Only because KM has posted LOTS OF BULLETTINS (tad) ON THIS (vERY JAMMER ) adf..... In the minute that you're thinking of giving up, think about why you lasted so long ... -
You bet, The shaft attached to the base of the assembly that holds the upper part of a "pivot assembly" to the lwr frame has broken an the motor is also shot. Tried to fix the shaft be re-enforcing it with a screw and building a better base to the shaft only after re-installing found the motor was shot.Comment
I do have here an used 611, but is better for you to find a supplier more near than me 1415-a105911.pdfLast edited by acusso1234; 03-31-2012, 07:40 PM.... In the minute that you're thinking of giving up, think about why you lasted so long ...Comment
