Re: i want to know what effect is of LD biss adjustment on my di450
Well, I'll tell you enough to get yourself into trouble: LD Bias refers to Laser Diode Bias. It will essentially balance the output of your laser to adjust for changes in the operating environment, such as degradation of the drum. Long story short: if you just learned what the "LD" abbreviation stands for, don't touch it.
http://www.justmanuals.com
Paul@justmanuals.com
It means if you start messing with it, and you don't know what you are doing, It will not like you!Leave a comment:
i want to know what effect is of LD biss adjustment on my di450? what is LD Bias Means?Tags: None
