need konica minolta bizhub 250 firmware please
  • andutzu2005
    • May 2025
    i get abort code 0000999e and i had to replace NVRAM
  • JustManuals
    • Jan 2006
    • 9838
    Re: need konica minolta bizhub 250 firmware please
    1st post and need need need.
    • mrwho
      Major Asshole!
      • 4299
      What does it have to do with firmware? If it isn't working after replacing NVRAM, what are the symptoms?
      Mascan42
      Ibid
      • JustManuals
        • Jan 2006
        • 9838
        Don't you know that a firmware upgrade fixes everything?
          • 22953
          If you've ever called the hotline, that's what they'll tell you, in this order:
          1) firmware
          2) main board
          3) next most expensive part on the machine
          • Dickie
            • Nov 2011
            • 190
              • 22953
              "You're the only one having this problem." when you've talked to four other dealers that can't solve the same problem either.
              "So what! It still needs solving, whether I'm the only one or not." =^..^=
              • andutzu2005
                i will try to change NVRAM but if it doesn't work this i want to try to load the firmware.
                • gpsorell
                  • Aug 2009
                  • 7
                  I have seen this problem many times. Here is the information from a Konica Minolta solution (I have had all 4 of these items cause this symptom).
                  Subject:
                  Machine keeps rebooting with abort code 0x0000999A.
                  Description:
                  Solution:
                  PROBABLE CAUSES:
                  1. Failed fax board interfering with operation of MFBS.
                  Replace fax board kit, FK-503.
                  2. There is a TCP/IP address conflict between the MFP and another device on the network.
                  Remove the Ethernet cable from the MFP and PING the TCP/IP address. If the PING succeeds,
                  speak with the Network Administrator and resolve the TCP/IP address conflict.
                  3. Possible damaged MFBS board and/or MEMS module located in slot 4 (CN4).
                  Replace the MFBS board and/or MEMS module.
                  4. Print jobs are in queue for the machine on the customer's print server.
                  If there are jobs in the queue, please disconnect the machine from the network, delete the jobs on
                  the server and reconnect the machine to the network.
                  • RRodgers
                    • Jun 2009
                    • 1947
                    i can get that for ya, get out a pen and paper and get ready to make a list.
