Machine trouble
  • agudmove
    replied
    Re: Machine trouble
    Fault Code - just could be the main motor needs changing. Check nothing is binding the fixer unit also.
    Paper Jams - with lift up tray in down position, make sure rear paper guide is right up to paper. If it happens all the time the torsion spring needs changing.
  • JustManuals
    replied
    Re: Machine trouble
    Paul@justmanuals.com
  • Mikey
    replied
    Re: Machine trouble
    Clean the clutch/solenoid connected to the main motor. Lubricate if possible. You can reset the trouble by turning off and on the machine.
  • Lukegw
    started a topic [Error Code] Machine trouble
    Machine trouble
    Konica 7115 copier when switched on displays machine troube on screen and then displays service call error code C0000. Other times it displays paper jam but when i open the door there is no paper. please help.
