Hi everyone
I have a strange problem with a Bizhub C250. Yesterday, i replaced the main motor, due to a C-5102 error. And after that, i powered on the machine. it was working well again.
But then i realized the life counter of the cyan IU was soon to end, i powered off the machine. Made a reset of the IU. Powered on again, and after it was finish to start up with the procedure, as if it was a new IU, it started to show a P6 error, related to the cyan IU. And i cant get it to print at all, it allways stops with the top of paper at the registration roller, as it doesnt run. And after some time, it shows a jam error.
I have tried to replace the main motor again. Replaced the Cyan IU. Cyan toner. Vaccumed the machine. And nothing helps!
When i look in "Level history" for TCR, the TCR for cyan is showing 12-13% and all the others show 6-7% How can that be??
I hope someone has got a clue, because i am totally blank.
