Print Meter Reads on C35, C360 and C452
    • 8206
    Please advise the best way to print off the meter reads on these three models. I can view the reads from the LCD but I need them printed, preferably while as a non connected copier.
    Thanks,
  • kingarthur
    • 1364
    Re: Print Meter Reads on C35, C360 and C452
    Is your question for real.....on the C360 & C452, if you can see the meter readings on the screen.....then you should be able to see the "PRINT LIST" on the LCD display...pretty self explanatory....
    • ni311
      • May 2008
      • 658
      Thanks,
      Non connected to what?
      On the C35, you should have a report to print in user menus, just read the manual.
      Konica Minolta Error Codes - Explanations and Solutions
      • wseyller
        • Sep 2012
        • 1129
        I will say that we use the word connected when we have a new machine that is to be setup in a customers office. Connected mean that it will be on a network and users can print to it. Not connected means that it will just be a standalone copier. The word connected would be on our paper work so that the tech who does the install knows up front the situation. Though whether it is connected or not isnt relevant since the list prints are internally printed pages.
        Sent from my XT875 using Tapatalk 2
        • SmellsHot
          Head Tech
          • 512
          c35 is ...utility/counter, user settings, print settings, print reports, stats page, ok
          C360, C452 is....Utility/counter, meter count, check details, print list.....
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
