C253 No power
  • Haroldbfix
    • 212
    C253 No power
    Actually the machine will light up for a couple of seconds and then power down, after that its dead,no LED's no light just dead. Any ideas?
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    My first guess would be NVRAM, or HVPS.
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
    • bowser
      • 25
      had this on c250
      have a c250 doing this and it is the MFP board.
      have changed mfp and problem gone.display comes up for apx one minute and then dies. powering off ond on repeats problem.
      • doma873
        • 24
        Have had NVRAM do this before. I would try it first the look at board..
        • Frostwolf
          • 71
          You could try the NVRAM recovery firmware.
          Worked for me before. There was a setting somewhere that had to be done or the machine said it was generic and a better looking boot screen came up. Can't remember which dip setting it was.
          • Rene
            NV-RAM recovery??
            I also thought of a NV-Recovery first but my informations are that there is no NV-Recovery Software for the C253 series available??
            I would be happy to get this software!!
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Same problem on a bizhub 250 and swapping the NVRAM fixed it.
              • Rene
                Swapping the NV-RAM will fix it for sure but my informations are that there is no NV-Recovery Software fore the C253 available...
                If my infos are wrong please let me know
                • Frostwolf
                  • 71
                  Sorry Somehow I mixed up the models. I have had to use the nvram recovery chip on the c250 not c253. Again sorry for mixup
                  • ni311
                    • May 2008
                    • 658
                    It's from the NVRam. There is a tool that writes to a CF card the files to reset the NVRam. The copier will keep all the counters but you have to do all the steps from the installation.
                    • DCPS
                      • Mar 2008
                      • 116
                      Hi
                      I think there are many of us, who would be interested to learn more about this tool, which "resets" the NVRAM on a C253. Can you tell us more about it? Can you find it from KM direct or is not oficial yet?
                      • laserman06
                        • Dec 2007
                        • 323
                        The tool is just a CF reader/writer. The software that you use to write the files to the CF is called ISW. You download both it and the files from Konica's website.
                        Ps 46:10
                        • DCPS
                          • Mar 2008
                          • 116
                          Yes i know the ISW although i make the CF cards always with the cygwin tool. But the question is: Is there a special file, which resets the NVRAM like the older C250/C252/C450/C352 serie? If i had the file there is no problem to make a CF card. As far as i know there is not such a file at the moment but ni311 wrote "There is a tool that writes to a CF card the files to reset the NVRam".
                          • ni311
                            • May 2008
                            • 658
                            Sorry guys, I thought we're talking about C250/252. From what I know so far there is no tool for C253, I guess we have to wait for a while....
                            Sorry again.
                            • Frostwolf
                              • 71
                              There is a special nvram reset tool that loads from the cf card (along with a key press when turning on the machine).
                              It is still available as a download on KMBS. Go to SSD, Click download firmware and more on the left. Do a search for "NVRAM" and scroll way down and pick the model you need (the older C250/C252/C300/C351/C450/C352 series and p models) make sure to get the instructions and follow them or your machine will no longer display Konica Minolta but will be generic)
                              It will have this name
                              Cxxx NVRAM Recovery Card Firmware version GCN-G4
