Konica 7020 F-28-3 error
  • jay-oh
    [Error Code] Konica 7020 F-28-3 error
    I've got a Konica 7020 and when attempting to make a copy it has a f-28-3 error.
    I've found a couple of posts about how to fix this issue, but I do not find them particularly clear.
    If anyone is able to give me some advice about a potential solution it would be much appreciated.
    My machine has done about 40 000 copies.
    Thank you.
  • LIOEEK
    • Oct 2012
    • 22
    Re: Konica 7020 F-28-3 error
    Check the HV casing for corrosion, check the insulators.. its on the left side door if im not mistaken.
    • juve
      • Dec 2012
      • 86
      first trasfer unit ,check or replace
      2.hv block at side door +insulaters
      3.arcing in the belly of conveyance(were the t.s. unit is placed)
      4.charge unit
