C6501 Konica Minolta. Just to help out. If you get the C3805 code and cannot find any logical reason, check the upper transfer roller on the transfer belt assembly. If you clear the C3805 and move past you might get the C4021 or C4022 ans when you run the proper adjustments from the manual you'll get an "Error 2" message.
I had one that was missing a bearing from the manufacturer and caused the shaft to break, resulting in a failure to drive the transfer belt properly. Just about drove me crazy!
I hope no one else ever sees this issue, but if you do, check that shaft!
