Biz hub c350 c0510 code reset
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Have seen a lot of posts in this forum asking how to reset fuser code on the biz hub c350. Here is a pic of the microswitch location inside front door you need to push to reset those codes. To the right of the k drum unit there is a cutout....the micro switch is inside the opening. Hope this helps someone in the future. There are a lot of erroneous posts telling people to cycle power while holding down the utility key. That info is for the biz hub c351 and c451.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Biz hub c350 c0510 code reset
    Its a carryover from the CF2002 series as its there too.
    • gyrfalcon
      I though you guys might have been pulling a joke, but after a few minutes on the floor with a flashlight I found the elusive micro-switch. It's almost like the designer used to install drug stash box release switches in courier vehicles.
      Thanks again!
      • blazebusiness
        • 1250
        Thanks again!
        Welcome---Glad that the info helped you.
        • OLADINEO
          Thank you Blazebusiness for the info on the Code Reset. I worked for me perfectly although I had to remove the cover at the location shown in the pic by Blazebusiness before I could see the reset botton.
          thanks.
