Bizhub C360/C280/C220 MFP board cooling fan failure code. Removed back cover and fan (FM17) part# a0edM10500 is spinning just fine so hope it's not the mfp board. I've seen these fans in other models throw a code even though they still turn so I'm hoping the customer gets off easy with the fan fixing the problem. These fans have a feedback loop that let's the copier know if they fail and sometimes the feedback loop is the problem even though fan functions.
Anyway----have any of you guys had to replace the mfp board for this code?
