Fiery IC401 - Win 8 - No. Copies
  • nicurazvan
    • Mar 2025
    Hello
    I'm using Fiery IC401 - C350 with Windows 8 x64 and I have a problem when setting the number of copies. Every time i set a N number >2 the printer gets N jobs and each job has N copies inside, resulting in N x N copies. I mention that everything worked fine when i used Windows Xp.
    Does anyone know how to fix this issue?
    Thanx in advice
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Fiery IC401 - Win 8 - No. Copies
    Do not use the printer popup for number of copies. Use the basic tab of the printer properties.
    Other option is to send one copy to the hold queue then run command workstation to select number of copies and print form there.
