C6000L + FS607 marks on prints
  • Texers
    • Apr 2012
    • 43
    Hello all,
    I have this C6000 + FS607 which is producing a mark like an indenture on the paper only when i print to main tray of the finisher.
    This mark is subscan towards the trail edge about 10 cm long. It does not match any roller, sensor flags , etc.
    I am fairly convinced that the mark comes form the finisher and not from the m/c itself though i've checked the paper exit assy for anything obvious in there and found nothing. Finisher has been stripped off to the bones , all rollers, plates guides, gates have been cleaned and checked.
    If i print to sub tray, mark disapear.
    Just to mention.. Mark is present on all paper weights.. From 120gsm to 350gsm. No matter if os face up or face down. Always in the same spot.. just the lenght varies a lil bit with the weight .
    Anyone came across with anything similar? Any ideea is welcome as im kind of starting to belive that i should think outside the box..
    Thanks in advance.
