Please Help with Bizhub C450 Touch Screen Calibration issue...
Guest replied -
Originally posted by sbus:353332Ok, how do you know this? And can you explain why it works sometimes and calibrates perfectly, works for hours, then is suddenly 'out of calibration'? Sounds to me like the calibration offsets that are stored in NVRAM are getting corrupted. Not that I disbelieve you (obviously I asked for help because I have no experience with this) but I'd love to understand the cause and effect before I install a new touch panel...Leave a comment:
Agreed, usually the top half of the screen is ok but the bottom half becomes unresponsive, or the buttons on the lower half of the screen register 2/3 cm further down from where they actually appear. New touch panel needed.Leave a comment:
Re: Please Help with Bizhub C450 Touch Screen Calibration issue...
With other words: Get a new Touch Panel......
You can get them locally from KonicaMinolta for USD 230.00 + or so,
or from us in Germany for USD 68.00 incl. postal charges. Payment by Paypal only.
touchpanel[at]rex-technika[dot]com
HansLeave a comment:
Guest repliedRe: Please Help with Bizhub C450 Touch Screen Calibration issue...
The touch panel needs to be replaced. For sure....
Paul@justmanuals.comLeave a comment:
I have a Bizhub C450 that won't retain touch screen calibration, and sometimes won't let me calibrate at all. First, the machine pretty much loses touchscreen calibration randomly; always when power cycled, but sometimes just for fun...! Second, the calibration isn't always possible (Accessability-->Touch Panel Adjust) because it doesn't always sense all four calibration points. But... if I power cycle, sometimes it WILL let me calibrate; and when I can, the calibration is always accurate and the touchscreen works fine *until* it just goes away again. I thought it might be the NVRAM; that doesn't explain why the calibration routine doesn't sense all 4 buttons. Also, all counters appear correct, and I have NO error codes. I thought it might be the touch screen cable; I disassembled the operator panel, removed and cleaned the touchpanel flex cable (DeOxit) and made sure it was inserted correctly. No change. I thought it might be the touch screen itself; but if it's bad, why would it suddenly start working when power cycled? I am stumped... Could really use another brain looking at this...
