A skinny black line in the middle of the printed image
  • technosystems
    • 34
    [Misc] A skinny black line in the middle of the printed image
    A skinny black line in the middle of the printed image!
    What caused? And how is it treated?
    Machine : Konica Minolta bizhub pro c5500
    Thank you for all
  • JustManuals
    • Jan 2006
    • 9919
    Re: A skinny black line in the middle of the printed image
    Paul@justmanuals.com
    • pager727
      • Aug 2013
      • 22
      It's not a copy? Check the drum. Probably has a scratch
      • rrrohan
        • Sep 2011
        • 1976
        i would hope somone working on a production machine would already have access to these.
        • technosystems
          • 34
          Dear, I have the service manual for my machine but i can't define this problem because i'm new in this field
          • technosystems
            • 34
            This line appear in printed or copied papers
            and Sometimes this line have some bends in some parts of it, other times there are no bends
            • minimerlin
              • 851
              Thank you for all
              What have you checked to diagnose the fault? Can you post an exampl? Stop machine during run and check all areas, could be from anywhere..Fuser, transfer, drum etc.
              Please do not PM me without asking first.
              • Ikon Princess
                • 126
                Wait a minute, you are in Cairo and people still complain about lines on their copies? Even with all that is going on there? All I can say is WOW really? Wish I could help you but I don't work on those machines. Best of luck to you and stay safe.
                • Saghir377
                  • Feb 2013
                  • 47
                  hy dear normally this line from drum or charging hope you confirm it from change drum unit and corona unit.
                  Some time there is thread of dust in-front of charging corona you must clean black part of process unit after that C if it is from intermediate transfer belt cleaning.Some time toner stone came out from cleaning unit and stay on cleaning blade this can make line by rubbing the belt.
                  If same problem just send a scan image and what step you took for the problem in detail
                  • technosystems
                    • 34
                    Working is a principle in life ..Thank you
                    • technosystems
                      • 34
                      Thanks Dear .. i'll try
                      • raffprint
                        Printshop Owner
                        • Jun 2012
                        • 11
                        I know this is an old post but did you figure out where the line came from? I got one on my C364 and there was a small slice on the intermediate transfer belt. Put a new one on and within a couple hours of it running, had another small scratch in the same exact spot. Dead center of the belt and in line with the one toner picker that's on it. I'm thinking a jam with coated paper could have caused the picker to wedge into the belt. Just ordered a new one again but would really like to know if this jam indeed could have caused it or if it's something else. Everything else looked good on the machine. Any suggestions would be appreciated.
                        • gurko_gg
                          Prod.Line Technician
                          • Sep 2011
                          • 43
                          Thank you for all
                          Hello,
                          remove the drum k and clean surface erase lamp.
                          regards
