Bizhub 501 paper jamming in registration area
  • vijaysharma
    • Sep 2008
    • 61
    [Jamming] Bizhub 501 paper jamming in registration area
    I'm facing the jamming problem in Bizhub 501. problem area registration clutch.
    what i done, I checked registration clutch it is ok registration sensor also ok
    secondly i checked the PRCB board it is ok, checked the OACB board also but problem is not rectify,
    is anyway to solve the problem
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub 501 paper jamming in registration area
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • mo0651
      • 1054
      I don't know what you mean by checked clutch?!? These clutches are known problems. There are two different ones right there. Change them both while you have it apart.
        • 14725
        mo0651 is right. Replace the clutches in registration area.
        • emujo
          • Jun 2009
          • 3009
          Originally posted by vijaysharma
          I opened the side door and the clutch did not fall out, there is a registration sensor in the place I think it's supposed to be, I didn't see any smoke pouring from the PRCB or OACB so they should be OK also. It must be a piece of crap machine that can't run a single piece of paper and needs to be replaced, not my troubleshooting skills. Emujo
          • vijaysharma
            • Sep 2008
            • 61
            Hi again
            mo0651 thanks
            i replace the clutch, registration sensor,PRCB board and OACB board also
            but the problem is not rectify
              • 14725
              Hi again
              mo0651 thanks
              What jam code/codes are you getting?
              • mo0651
                • 1054
                Jam codes?? There are two clutches there, Did you replace both? Are the rollers turning?
                • vijaysharma
                  • Sep 2008
                  • 61
                  HI,
                  jam code is J-3100
                  • vijaysharma
                    • Sep 2008
                    • 61
                    again
                    both clutches replaced and rollers not turning
                    • rahadyan himura
                      • Jun 2012
                      • 21
                      yeah, if you copy single is okay and if you copy double sided and jammed at registration roller, right?
                      you need to check and give some oil at (26NA 2024 2) SEPARATE GUIDE PLATE. if still same of course you need to change registration clutch (57AA 8203 0) CONVEYANCE DRIVE CLUTCH.
                      i hope this can help you.
