Konica Minolta Bizhub C353 Print Stop
  • pdcopiers
    • Jun 2014
    • 15
    #16
    Re: Konica Minolta Bizhub C353 Print Stop
    Originally posted by nvram
    Hi, Did the machine return an IP address starting 169.254 if so the nic has gone to sleep, it is possible to awaken it by changing the network speed in detail settings of the network setting tab.
    Thank You, I have to go back to this client today and I'll try to change the network speed. I think this is the problem because when I tried to set by DHCP it was change to 169.254.... I let you what happen today or tomorrow.
    • copier tech
      • 8144
      #17
      Yes i've had the same issue, change the netword card speed fron Auto to full duplex
      • Hansoon
        • Sep 2007
        • 3385
        #18
        Many moons ago I ripped out the RJ45 connector by just moving a BH-C-253 and forgetting to remove the network cable first.............
        Hans
        • allan
          RTFM!!
          • 5462
          #19
          If you are running on SLA's chiping is a must to beat the competition on print costs. We chip(reset) those tanks in a office environment up to twice with not problems.
          Whatever
          • pdcopiers
            • Jun 2014
            • 15
            #20
            Hans
            Well, my client moved the machine few step, but he didn't mentioned that his forgot to remove the network cable first... How did you fixed that?
            • Hansoon
              • Sep 2007
              • 3385
              #21
              Post from
              01-28-2014
              Re: Time to admit to all your boo boos
              Originally Posted by Hansoon
              My Booboo of today:
              BH-C-253 ready to be transported to the customer. Forgot to remove the TCP/IP cable when I moved the machine........
              Two of the contact wires came out of the socket and are twisted beyond repair. The plastic and the shielding of the socket are damaged too.
              Hans
              OK, removed the socket from the board (*note to oneself, with the next booboo buy a decent de- soldering equipment*) and reconstructed everything. Machine is up and working now until my next goof-up........
              Hans
              • pdcopiers
                • Jun 2014
                • 15
                #22
                Post from
                01-28-2014
                My Booboo of today:
                Hans
                Hans
                Yeah I remember that I'd the same problem long time ago, but already check the wires in the socket and there are look fine...
                • pdcopiers
                  • Jun 2014
                  • 15
                  #23
                  Hi guys, copier tech is right. The Machine is working again, Network card is working. This is solution for this problem:
                  Change the netword card speed from Auto to full duplex
                  But Before that, measure the socket has not damage...
                  Thank You guys for all your help.
                  • copier tech
                    • 8144
                    #24
                    Boom! Rep power please!
