C451/550/650 webtool time out
  • toly
    • Oct 2007
    • 22
    On all installation the last few month i have discovered that when you are using webtool the machine disconnect after very short time.
    any ideas where this timer is set up?
  • nmfaxman
    • 1702
    Administrator mode.
    Default code is 00000000.
    Look for timers and set them all to 240, except for panel reset time.
    • toly
      • Oct 2007
      • 22
      Admin code is 12345678
      • konisolver
        System Engineer
        • Oct 2007
        • 137
        There is no way to set the timer for this timeout. The only solution for this is to log-out and make sure to select HTML instead of flash. This also eliminates the "socket error" on the screen.
        • toly
          • Oct 2007
          • 22
          Sounds like an ok solution, thanks
