Help with Bizhub C650 - Bad Prints (Urgent)
  • stryder
    • Apr 2014
    • 33
    Hi guys, I need your input on a situation that I have on a C650. Basically, it is printing out this demo page photo(3).jpg. I've tried changing the, Drums, MFP Board, HVPS, PWB-MC, Laser Write Unit, Power supply. But none of them solve the problem. Then another problem occurred, the machine boots up to a blank screen with the start button lighted up orange and there is power. Any help would be greatly appreciated. Thank you
  • aligis
    • Jul 2010
    • 56
    Re: Help with Bizhub C650 - Bad Prints (Urgent)
    how about internal tests like gradation etc. is this copy.. have you tried to see on Transfer bet while printing etc..
    • aligis
      • Jul 2010
      • 56
      what about fuser unit ?
      • stryder
        • Apr 2014
        • 33
        this is a print, i have tried the gradiation and full page print. all the same. fix the not powering issue though.
        • stryder
          • Apr 2014
          • 33
          not the belt, not the transfer roller, not the fuser... out of options other than a firmware update...
          • aligis
            • Jul 2010
            • 56
            ok please feedback after firm. update. Gudluck
            • mitchl
              • Apr 2007
              • 501
              Youre kidding right?
              • mitchl
                • Apr 2007
                • 501
                Hi guys, I need your input on a situation that I have on a C650. Basically, it is printing out this demo page [ATTACH=CONFIG]25236[/ATTACH]. I've tried changing the, Drums, MFP Board, HVPS, PWB-MC, Laser Write Unit, Power supply. But none of them solve the problem. Then another problem occurred, the machine boots up to a blank screen with the start button lighted up orange and there is power. Any help would be greatly appreciated. Thank you
                The blank screen....... Now I'm saying this in a very smokey voice "sounds like you have the NVRAM blues"! Try hitting the firmware and /or running the NVRAM recovery program.
                On the off chance you get this pig on its feet try stopping a copy midway through, yank the t-belt and see what the image looks like. If its good look towards the t-roller or possibly and HVT issue.
                • stryder
                  • Apr 2014
                  • 33
                  Fixed the issue but now the scanner prints out with a pink fuzz on the whole page. only on scans on both glass and adf. prints looks good. changing a working ccd board didnt work. receding the plugs on the board next the where the adf plugs into made the scan image worst, so will try out those first. thanks for the inputs
                  • mitchl
                    • Apr 2007
                    • 501
                    And all these problems showed up at once? Just to make sure check the scanner to MFP connector on the right end of the machine I have seen them for what ever reason loosen up and create weirdness. You said you corrected the blank screen issue, how, what was the prob?
                    • stryder
                      • Apr 2014
                      • 33
                      The blank screen was due to the mfp failing, so had to put another mfp in and is working perfectly fine now. But I still have this problem on the scan photo(4).jpg. Prints and everything comes out perfect but the scan is bad. tried changing ccd board, the other boards next to adf plug, even the unit in the middle of the scanner and it still comes out like this. any help on this one would be nice.
                      • stryder
                        • Apr 2014
                        • 33
                        solve the issue, machine done and out finally. On to the next...
                        • Blizzoo
                          • Aug 2013
                          • 608
                          i think it's nice from you to post how did you solve your two major problems described.
