Konica Bizhub C25 scanning?
  • skibum
    Independent Service Tech
    • 227
    Can you scan to a folder on a laptop on the Konica Bizhub C25 as listed? It is hard wired to a wireless router port then it goes wireless from the router to the laptop but is having user name or password errors. error 0109 The user name and password are correct. Any ideas would be much appreciated.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2142
    Re: Konica Bizhub C25 scanning?
    some routers do not work properly in this regard and its not the mfp. Elcheapo routers have issues dealing with SMB between wireless and wired networks on the very device itself, I have had this before.
    Try it with your laptop itself on the wired network and see if you can even connect to the wirelessly connected laptop, if you cant the mfp hasnt got a hope in hell. Not your problem then and you can wash your hands of the matter till they buy business grade equipment or set a up a real network instead of a home grade / toy router.
