C6000 Fuser ghosting
  • KM1Amsterdam
    • Jun 2014
    • 36
    So after 50k pages, fuser unit starts to ghost copy on paper. Replacing the fuser belt helps, but after 50k the same problem returns. Customer had 2 fuser units, both the same, after 50k fuser belt needs to be replaced.
    One fuser has been refurbished completly, new rollers, bearings, still same problem after 50k.
    • 23008
    Re: C6000 Fuser ghosting
    Glossy media? Especially inkjet paper? =^..^=
    • KM1Amsterdam
      • Jun 2014
      • 36
      Not really just uncoated heavy stock
        • 23008
        And heavy paper settings? =^..^=
        • KM1Amsterdam
          • Jun 2014
          • 36
          Sure + speed down & cpm down ofcoursem tried high and low temp settings also.
            • 23008
            OEM toner and developer? =^..^=
            • allan
              RTFM!!
              • 5462
              Expensive exercise! Is TCR levels ok? Any specific color or all colors the same?
              Whatever
              • methogod
                • Dec 2008
                • 921
                TURN OFF SPEED DOWN, should not be an option.
                If stock is very heavy there should not be an option
                Speed down is to slow down paper running faster then it can move, very light stock, fine paper.
                CPM - is FINE if you need it... its cycles per minute, that slows the cycles so its only feeds 1 sheets though before it starts the next, good when sheets are crashing.
                what is specs of paper?
                did you try another brand of the same paper?
                what size is paper?
                can you post image?
                when you changed everything, did you replace the gear that control the pressure down control...
                thanks,
