I am having some intermittent snake pattern banding about 1 inch wide. Seem like a charge issue. Anyone had that issue? Anyone found a solution?
Bizhub 223 snake alike patern
Re: Bizhub 223 snake alike patern
Have you done anything? =^..^=If you'd like a serious answer to your request:
Is there a mouse in the copier, they usually attract snakes.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
ianferron
I try replacing drum and transfer roller with problem coming back. I did replace the dev unit and put fresh dev mix and problem is finally gone. I am trying to post a sample. Still not sure what was the problem. On the snake pattern I can rub off what feel like dev mix.Comment
Fong Kong toner?WhateverComment
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
ianferron
I didn't had a sample with me and customer was closed for the holiday. I still have the dev unit and will inspect for hole in mylar covering the mag roller. Seem like a common problem with these models. Had another 363 with same problem 3 weeks ago, cleaned the charge corona unit but they never called back.Comment
ianferron
Customer called with same problem again. New drum, new dev unit. I am pulling my hair cause I have no idea what else could it be.Comment
I would put the new drum and dv unit in another machine. If it works in another machine, I would start going backwards into the machine and change the hv power unit.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
