Hi,
I installed a new bizhub Press C1060L few days ago, IC-602A is also installed.Machine is working perfectly.I have installed Color Centro /Job Centro for color calibration, but when i tried to connect machine with these applications, an error occured "Failed to connect to the printer" I have tried several times but error is same.I installed Color Centro/Job Centro on three different workstations/Computers but error is same on every system.Machine is on the network.Easily searchable.Network printing is working, PING confirmation is working. Accessible via web browser. I have installed latest .Net framework, Java Script is allowed for the Job/color Centro.Firewalls are disabled.But error is still there.I have also check the "JSP" port no which is also default and OK. I have re-installed the IC-602, its additional RAM and checked the HDD connectors, but error is still same.The firmware version of Machine is 15, i have re-installed the firmware 15 again, but after this error is still there. I tried every thing i know but failed to connect. Can anybody tell where is the problem? and its solution.
Many Thanks!
Many Thanks!
