BizHub 223
    replied
    Re: BizHub 223
    Thanks for the response allan, but I just found the setting I was looking for. It is in Admin mode -system settings - default bypass paper type setting.
    It was in the user manual. Oooops.
  • allan
    replied
    Re: BizHub 223
    Dono about that what happens if you change the default to current setting under copy settings after setting it up?
    started a topic BizHub 223
    BizHub 223
    I have noticed on the BH223 series of machines that the bypass does not retain paper settings when it runs out. So, when paper is added you have to set it up again. Any other machine I have tried holds the previous settings.Has anyone noticed this, or does anyone have a fix for this.
