How to Change the IP address of INEO 250
  • austria
    • Jul 2025
    [Misc] How to Change the IP address of INEO 250
    can somebody give me a step by step process on how to change the IP address, subnet mass and default gateway for INEO 250?
    • 23007
    Re: How to Change the IP address of INEO 250
    I think, If I were you, I would check in the service manual, page 130. You don't have one? Look here:
    Google is pretty miraculous, isn't it? =^..^=
    • subaro
      • Oct 2010
      • 1274
      the network setup and settings would be found in the operations manual.
      My correction. Also can be found on page 150 of the service manual that blackcat replied with..
      according to the service manual , this machine is equivalent to bizhub 200/250/350 with europe and US settings.
      • shamnad abdullah
        service engineer
        • May 2015
        • 24
        press utility/counter=>admin management=>enter"00000000"(default)=>network settings=>ip adress settings
        here you can change the ip adress....
