hi everybody,
i want to ask about the consumable parts life in the machine 454e ,
normally you can check every part and see the remaining percentage of it , and it's the REPLACING cycle you have to replace it when it ends right ?
great , the first part reached its end life cycle(after the toner) is the drum i changed it with in new one , after that it came the toner filter , the ozon filter and the transfer belt and i couldn't get theme at time to change them, so i had to find a way out witch i did . i could reset the counter of those tree parts without changing them
my questions is : is it healthy for the printer to just reset those part counter every time it ends ? and is there a way to do it for the drum also because the last one i changed looked fin and can be used
