C351 - bypassing the IC-402
  • bicouncz
    • Jun 2025
    MFP Controller BOOT Program 4037-1E00-G00-05-000(00)
    MFP Controller SubSet Program 4037-1F00-G00-21-000(00)
    MFP Controller 4037-0100-G00-D6-000(00)
    Operation PANEL Message Data 4037-8100-G00-C5-000(00)
    FAX Board Controller1
    FAX Board Controller2
    IR 4037-0023-G00-15-000
    PRT 4037-0050-G10-28-000
    LPH 4037-0053-G01-00-000
    ADF 4582-24G0-08-00
    Finisher
    System Controller 4037-1000-G00-D6-000(00)
    Printer Controller
    Printer Controller-Font
    Printer Controller-Demo Page 4037-3E00-G00-00-000
    MIO 4037-5000-G00-47-000(00)
    PSWC 4037-5100-G00-89-000(00)
    MIB IF 4037-5200-G00-44-000(00)
    IPP IF 4037-5300-G00-04-000(00)
    External Controller IF 4037-6100-G00-44-000(00)
    TCP/Socket 4037-6300-G00-15-000(00)
    Open API 4037-7000-G00-86-000(00)
    Operation PANEL 4037-8000-G00-C6-000(00)
    CSRC 4037-8300-G00-67-000(00)
    PIC 4037-8200-G00-16-000
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C351 - bypassing the IC-402
    If you want to remove and throw away the firey this is not a problem, you just need to change the controller number in service mode back the internal number - which I do not remember. It is is in the service manual, which i do not have for these anymore. Someone else will chime in shortly I'm sure. It is really not a big deal and not a firmware issue.
    • bicouncz
