Tray 5 does not raise in this unit. It was saying paper empty with paper but that changed, now it thinks it is already up.
Here is the symptom: It started that it thought it was empty. That is not happening now. Don't know why. May be when I was
checking the sensors.
Here is what I have done. I swapped the sensor assy from tray 4 to tray 5. No change.
The customer has another PF602 so we took the control bd out and replaced the one that Hytec thought
was bad. We thought that because when I unplug the upper limit switch, the tray begins to raise. Plug it back in and the machine
thinks the tray is up.
Now I suspect the connector that the tray plugs into. But I am having trouble finding the pin # on the connectors because it is on the
bottom of the machine, up against a door that has black insulation on it. Very little light or room. My eyes aren't as good as they
use to be, so I need a magnifier and flashlite to see. Connector 855 is that the connector that the bottom tray connects to.
I am looking at the diagrams for a clue. The machine must see something on that pin when I unplug it.
Has anyone seen this problem on the PF602.
I wish I could be brighter than my flashlight all the time, instead of just some of the time.
DR
DR
