B1250 heat insulating sleeves
  • allan
    RTFM!!
    • 5429
    Hi guys.
    So i seem to have a problem with disintegrating insulation sleeves. I replaced a set about 400K back and it was ok then missing just heaps of of graphite like powder.
    So i F#&^ up. I did check the parts manual to check if there it no missing spacers and that the assembly is complete before i replaced the bearings and the sleeves.
    Any body seen this?
    Whatever
    • 22599
    Re: B1250 heat insulating sleeves
    Both my PRESS 1052's have 2.75M and the original collars are holding up fine. When you replace the collars this time, I would recommend that you set the fixing pressure for each of the trays to light pressure. On my machines there is very adequate fixing with less paper curl, and potentially less fatigue on fixing drive components. =^..^=
    • allan
      RTFM!!
      • 5429
      Thx i will try that. Is that setting under the tray setup?
      Whatever
        • 22599
        Yes: Machine > Tray Setup > select Tray > middle section Change Setting > ...
        • allan
          RTFM!!
          • 5429
          Thanks BC.
          I did set the trays to "weak" i hope that helps because i can't see anything wrong with the assy.
          Whatever
          • allan
            RTFM!!
            • 5429
            It needs a special kind of heat grease for those sleeves. Missed the note in the manual.
            Whatever
            • andyf424
              • Jun 2013
              • 126
              uh oh.... I've got a couple 1250's and I've never lubed the sleeves. Looking into that now.
              • allan
                RTFM!!
                • 5429
                Look for the note on the PM procedure.
                Whatever
                • andyf424
                  • Jun 2013
                  • 126
                  Multemp FF-RM, is there a Konica Minolta part number for that so I can have my parts guy get it? Or, is it just a generic, over the counter sort of thing? I checked the parts manual and the consumables guide and didn't find anything.
                  • andyf424
                    • Jun 2013
                    • 126
                    A little googling turned up 00GR00260, I'll see if my parts guy can get that.
                    • allan
                      RTFM!!
                      • 5429
                      I can seem to get the grease in South-Africa. Any alternatives that should work. i am still getting broken bushings on one of the machines.
                      The pressure adjustment works well on one machine, so not sure why they are not lasting.
                      Whatever
