Any one knows how to deal with this, im thinking it has to be done with ram reset how how's the procedure going to simulation stop 07139 where i am going to start?
Bizhub c451 control panel freezed, start key not responsive
Re: Bizhub c451 control panel freezed, start key not responsive
if it starts up fine then locks up solid at the copy screen, its probably the ram stick in bank 1 thats failed, if the ram in bank 0 fails the machine wont progress past both led's on the scanner being on and a black screen.
I personally would try ram first before jumping to messing with NVRAM, its a hell of a lot less work to do if it is not required. -
As suggested, start with ram.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
