yellow background print bizhub c364
  • Synthohol
    replied
    Re: yellow background print bizhub c364
    Originally posted by dhaneshkumar
    I have same issue konica c452 printer plese help me.
    upgrade to a newer machine.
    or maybe tell us what you have done so far? like any of the advice above?
  • dhaneshkumar
    Guest replied
  • shamnad abdullah
    replied
    Originally posted by toony
    I use a bizhub c364.
    Yesterday it started printing all yellow background for any colored print i have. gues it might be some sort of yellow toner spill. but it does not do this when i do a print in greyscale. pls what can be done!
    Remove the high voltage board and assemble it,make sure that all connections are touching properly
    best of luck
  • KingofMorton
    replied
    Cut a long strip of paper and slide it under the yellow drum and block the laser glass. If the yellow goes away then the laser is the problem.
  • allan
    replied
    Have you tried to use the corona cleaner?
  • fixthecopier
    replied
    Most likely, replace the yellow image unit.
  • toony
    started a topic yellow background print bizhub c364
