Bzzhub c452 baclk IU or Transfer belt?
  • konica7022
    • Nov 2008
    • 132
    most of the time get this smudge stain on top right corner black prints only and mostly on First Print or copy?
    is it K IU or transferbelt? the colors come out fine
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: Bzzhub c452 baclk IU or Transfer belt?
    [ATTACH=CONFIG]29734[/ATTACH]
    Sounds like iU. Try and post an image of the issue, can't see on the one you have posted.
    The gene pool could use a little chlorine.
    • konica7022
      • Nov 2008
      • 132
      Image enhanced and contrast increased for better view
      • femaster
        • May 2011
        • 1417
        Still a little hard to see on my screen, but with the enhanced image, it looks like it goes across the entire top of the paper. Based on that observation, it doesn't look like the streaking defect goes from the edge of the paper to the other edge of paper, it looks like it cuts off within the "image" area of the page, and if that is the case, I'd look at the image unit first. If it were from edge to edge, then I might start with removing and cleaning the transfer belt cleaning unit.
        • allan
          RTFM!!
          • 5445
          How does that work?
          Whatever
          • allan
            RTFM!!
            • 5445
            Its faint but looks like cleaning blade failure.
            Print half-tones and have a look if the black appears on the CMY prints if it does its the black drum.
            A C452 does not use an IU for K, its a DR and a DV unit
            Whatever
            • femaster
              • May 2011
              • 1417
              Even though I'm guessing you are referencing the original posters words, I too made the same mistake. You are correct; I'm still trying to get a handle on all these models myself, and convert my terminology from Ricoh to KM... I'm getting there... lol
              • hotfuser
                • 180
                defect is on the upper right side of the paper[ATTACH=CONFIG]29735[/ATTACH]
                usually it is the ITB ecspecially if it is only on the first copies.
                it is the mylar below the cleaning blade assy that gets damaged.
                • HoonBoy
                  • May 2011
                  • 130
                  Try adjusting the Transfer Belt-Cleaning Bias first. positive +5
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2142
                    I just install a new transfer belt when I see that. Its the belt cleaning section.
                    • femaster
                      • May 2011
                      • 1417
                      How does that work?
                      How does what work?
                      • konica7022
                        • Nov 2008
                        • 132
                        Guys sorry for the late reply
                        "Try adjusting the Transfer Belt-Cleaning Bias first. positive +5"
                        where in service mode is it ? how to get there ?
                        "I just install a new transfer belt when I see that. Its the belt cleaning section."
                        i was thinking the same so i removed the TB opened it it was filled with toner, cleaned it , closed it and installed back in
                        It is much much better now but i those spots are still there
                        there is a ring around the Black Drum(see attached picIMG_20150706_001626.jpg) either the black drum has issue or Drum Cleaning balde/developer
                        my question should i change the drum alone or change the Entire unit along with developer?
                        • allan
                          RTFM!!
                          • 5445
                          I would just change the drum if there is nothing visibly wrong with dev tank.
                          Whatever
                          • Desert Rat
                            • May 2008
                            • 1089
                            Check the black Developer unit for excessive dusting. Stop the page before it gets to the transfer and check the paper and transfer belt.
                            I'm thinking that something is getting dusted with toner.
                            DR
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2142
                              i don't remember the last time i was able to reuse a dv-612 on a 652 series, they are always visibly worn in the centre by the the time the first drum life is up. I always change the drum and dev a pair now. Some techs/companys may just ignore the poor print quality most noticeable on solid blacks and reuse it but I cannot.
                              On the other hand the dv-711 on the big 4 series does actually consistantly last life, I dont know what they changed but it made a difference.
