Need some help!
We got a DP-772 that is throwing a jam "Skewed originals fed." The paper is stopping right at the registration rollers. The registration rollers will not engage and the lift tray drops.
This was after replacing the following:
DP SHD PWB
DP Main PWB
All sensors in DP
All motors in DP
When running sim 243, all operations run correctly. When running sim 203, with the option of no paper loaded, we can run it and then slide a piece of paper in and it will run correctly... no problems. Any other method of testing with paper in the tray, we get the above mentioned results of skewed original fed.
Checked voltage to the feed sensor and the skew sensor, both registering at 3.3 volts.
Also, this is now being tested on our machine. It came from a customers machine, so the machine has been ruled out as well.
If anyone has any idea whatsoever, would love to hear them.
DP SHD PWB
DP Main PWB
All sensors in DP
All motors in DP
