Taskalfa 3551ci - Error code C8350
  • Arteminium
    • Apr 2016
    • 8
    So I've just spent the last 7 hours running up my first Kyocera, I have it all put together, turn it on, print off a status page everything looks fine.
    I opened the door on the finisher to see if it was registering, it was, so I closed it and I got this error
    C8350
    CF side registration motor 1 error
    (4000-sheet finisher)
    When initial operation, CF side registration sensor 1 does not turn on within 1 s.
    What I'd like to know is, where the CF side registration motor actually is, along with the side registration lower guide, so that I can take a look at it/ troubleshoot.
    Also if anyone has an idea for how to fix it, suggestions would be much appreciated.
  • CWP
    • Jun 2013
    • 168
    Re: Taskalfa 3551ci - Error code C8350
    Arteminium,
    The CF side registration sensors and motor are in the booklet folder. The sensor is most likely just not plugged in; make sure the side guides move freely back and forth. To get to the switch and connector I believe that you need to remove the booklet folder from the finisher and remove a plate from the bottom of the booklet folder. It's been a very long time, so I may be completely wrong on how to get to it.
    • Arteminium
      • Apr 2016
      • 8
      Originally posted by CWP
      Arteminium,
      Thanks man, worked like a dream
