CS 2551ci noise when running the paper feed motor
  • COPYDOCAZ
    • Mar 2015
    • 110
    This unit makes a rattle or vibration I narrowed it down by running individual motor tests to the paper feed motor. seems to be coming from the exit aria or the transport section but i have lubed the gears and bearings with no luck. Any ideas would be appreciated.
  • qbert69
    • Mar 2013
    • 1152
    Re: CS 2551ci noise when running the paper feed motor
    ...does it have a bridge unit and finisher?
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • COPYDOCAZ
      • Mar 2015
      • 110
      yes it do but the noise seems to be located in the regestration roller aria
      • qbert69
        • Mar 2013
        • 1152
        Is it squeaking?!...It's probably a plastic roller on metal shaft noise! In instances like this, I usually just get a can of WD-40 with a schnozzle and start spraying into the plastic roller metal shaft locations--usually the pressure rollers that push against the drive feed rollers. It could also be at a brass bushing at the end of the shaft of a drive roller. What you can do is take a fairly narrow funnel (you can roll one out of a piece of paper, yes, a funnel and stick it up to your ear while the machine is making the sound....this will help you localize and pinpoint the problematic location. I some instances, the vibration/sound travels the length of a shaft thus causing the whole cavity to resonate, making it harder to pinpoint the sound source.
        Good Luck!
        • tonerleak
          • Mar 2012
          • 67
          This may seem like a long shot but we had a 3050ci that was making a strange rubbing/chirping noise when running the feed motor looking for the noise, ended up being the drum unit. These models seem to make a lot of annoying noises once they get some miles on them. Noise= headache
          • COPYDOCAZ
            • Mar 2015
            • 110
            Well I figured it out ... there was a loose cover on the inside of the rt side door that was rattling. found it by accident when I went to remove the cover. WIERD... OR WHAT
            • tee
              • Aug 2014
              • 79
              I had one of these intermittently making noise near registration.
              I had to replaced the reg clutch under warranty.
